Can anyone tell me which port is which on the proportioning valve? (73 Disc/Drum valve) Like which goes to the rear, which to the front, which from the master etc....Pics would be even better!
Ryan
Ryan
The way you have it hooked up is kind of the same since A, B & C are basically nothing more than a "T" But A is the input before the split to right/left and should be a bigger fitting & line size I think.vitamindart said:mines hooked up different C is rear res on master (front brake out) A is pass front and B is drivers but your way makes more sense humm
mine doesn't pull or any thing??? maybe i should change my lines around
