1 - 10 of 10 Posts
Aluminum plate over the blower motor hole same with the heater hose holes. Under the dash I mounted another plate to that one and mounted my MSD to it.
my dog had a toy ball that i shoved in there and fit perfectly -0*(,then about a year later i got around to doing what dartracer did.
I did what Dartrace did. I did it with plexiglass first time around, this time I'm using lightweight tin.
On an old Cuda I had a long time ago I cut up a pop can and sandwiched it between the ring and firewall. :D
i think dart racer had it covered,sheet metal or aluminum plate is pretty much the way to go unless you want to fab up a controlable vent box,which would'nt be too hard.
for the firewall I used sheetmetal the first time
And a welder the second time around.
Under the dash I made some more sheet metal plates up If you want to get really fancy you could always weld up the cowl vent so air cant get in.
1 - 10 of 10 Posts
