Jim doesnt the 8.25 have only 4 bolts holding the backing plate on?Jim_Lusk said:Yes.
Bear in mind that the axles need to have the correct offset from the housing (B/C/E axle spacing).
Not necessarily. Small bolt a-bodies used a thinner wheel flange that was closer to the axle housing than big bolt cars. You can't use big bolt brakes with re-drilled axles.moparn1 said:ok so if there are both a-body rear ends i should be ok right?
