I started the rear bar today. My set up is a standard length Dana 60 (your 8.75" should allow more room for bar clearance) and relocated super stock springs. I've kept my eyes out on the freeway, checked parking lots etc and found the following bar to be the closest to being able to fit. The 1999 - 2003 Ford F 250 / 350 4 x 4 front way bar. The front leaf springs measure the same outside to outside as a Dart with relocated springs. Unfortunately the bar is 1 1/4" diameter. Is this going to give me a handling problem. I can't see it flexing that much. Maybe it won't be too big of a deal with the narrowed spring centers.
Also, this obviously won't work with Cal tracks.
Anyways here's a few pics.
I forgot to take a picture of the restraining strap before I filled the holes. This bracket measures 5 3/8" long. The old holes have been filled and ground down. It's easiest putting the steel in a vise and perform an uphill mig weld to both sides. It fills fast and no need for copper backing.
cut the brakcet down to 4 3/4" long and redrill 2 - 1/2" holes on 3 1/2" center to center to slide onto your u bolts.
Attach it to the underside of your shock plate. Perfect fit.
Another view.
Another view.
