1 - 5 of 5 Posts
WELL I AM NOW GOING TO MOVE MY SPRINGS INWARD WITH THE OFFSET SPRING KIT, I WANT TO USE THE SUPER STOCK SPRINGS. BUT WHICH ONES? I HAVE A 72 SWINGER AND SMALL BLOCK, 4.56 GEARS AND 30" TIRES. MOSTLY STREET DRIVEN, RARELY AT THE TRACK, DO I USE 2800 LB, 3200 LB OR 3400 LB SPRINGS?
:D I use the 2800# and my car is 3350# I like it 1.51 60ft. no traction bars,no wheel hop. >:D I did have to weld a piece of .125" plate where the stubber hits the floor,it bent it bad. -0*( MAX43
I'll tell you this much: You DO NOT want the 3400# manual trans springs. My pickup truck has softer rear suspension! Most guys use the 002/003 springs. Those are the 3000# springs. I'll be buying something different, that's for sure. The car in my sig pic has the 3400# springs and is only missing the trunk lid and gasoline.
This is how my sons Dart sits with the 002 and 003 3000 lb springs. They work nice as the suspension is all stock other then these SS springs and we use no snubber. It has run 11.55 @ 116 with a 1.61 best 60 ft so far with 3.91's and Hoosier QTP 26 x 9.5 tires. Ron
1 - 5 of 5 Posts
