1 - 3 of 3 Posts
Sorry about asking but I just completed my LBP Brake swap useing F body spindals and calipers and need to know if I use the stock 73-76 A body rubber caliper hoses or the F body style?
The F body ones have a bracket partway up from the line at the fram that I have no mounting hole for that I know of On my 68 and I have not looked at the stock A Body Lines. o----o<>
I had a 72 Scamp that I converted to LBP disks.  The calipers were mounted to the rear of the spindles.  I used the 73+ hoses.  No problems. I also just finished a 75 dart with disk brakes.  the calipers were to the front of the spindles.  Same hose, no problem.  The routing is just different.    both set up are fine.     bbscamp
1 - 3 of 3 Posts
