1 - 3 of 3 Posts
how can i fix these rust holes
If your gonna do it right,your going to have to remove the window first.Cut out the rust,fabricate some metal and weld it in place.Your going to have to get it fairly close,try to use as little body filler as possible.If you try to fill that (even with gorilla hair or mar-glass or whatever)i guarantee it will crack and fall out with a repair like that.Your only other choice is new panels if they are even available or good donors.Do it right whatever your choice is.
1 - 3 of 3 Posts
