1 - 6 of 6 Posts
· Registered
You will need to 1st cut out the old handle.2nd Make a patch to cover it in sheet metal. 3rd weld it in. 4th.get a shaved door handle kit which will include bearclaw latches and remotes to open the doors. Also make sure you have a hidden wire connected to the latch to open the door in case of electrical failure.Check out some of the street rod mags for a shaved door handle kit. There are lots of them out there
· Registered
Correct me if I'm wrong but don't the bear locks allow you to setup a cable so you can get in if you have a loss of power? With the solenoid in the door, if you have a loss of power there seems like there is no way in. You've got to have something set up I would imagine.
· Registered
You can run an emergency release cable to the door mechanism. Bearclaws are an optional replacement for ancient door latch mechanisms (such as in street rods).
1 - 6 of 6 Posts
