1 - 20 of 25 Posts
Relocated my springs last weekend. All went well, but now when I drive over a hard bump in the road such as a split in the pavement or a pothole, there is a hard slam in the rear. Suspension travel is fine when I push the car up and down. I have to bounce it pretty hard to make the pinion snubber hit. The snubber has about 3" inches before contact. The hard slam doesn't happen when driving over rolls and dips in the road, only when hitting something hard. Didn't have this problem before relo with stock wheels and tires. After relo I am running 245/60R15's on 15 x 8 Weld Prostars. My springs dont have much arch. They are stock five leafs off of a four door smallblock car.
I'm concern that my shackle angle is not correct. Could this be the problem?
__________________
BONEYARDS BEWARE!!
I don't have witnessing knowledge about it, but have heard that if you tighten your u-bolts that hold the axle to the spring too tight, you'll get a booming noise in the car. Did you torque them to specs, or just crank them down?
Discussion Starter · #4 ·
19swinger70 said:
your shackles may be letting the rear spring eye hit the frame. some people have had to address this issue.
My shackles are very close to vertical. Have checked for any marks that would indicate spring eye hitting frame. tnku
Discussion Starter · #5 ·
I just cranked them down. I'd like to hear more about this u-bolt to tight stuff tnku
Are your shocks too short? Thats what it sounds like, easy to tell, take em off and go for a ride, it'll feel bouncy but you'll be able to tell that way...
Ryan
Discussion Starter · #8 ·
70 Dustpan said:
Are your rear shackles leaning to the front or the back of the car?
Shackles are straight up and down, top shackle hole is to the front about a 1/4" more than the rear spring eye. tnku
Discussion Starter · #9 ·
Ryan
tnku I'll give that a try.
Ryan
No problem, I had an old camaro in high school that we put 6" lift springs in and didnt think about changing to longer shocks and it reacted EXACTLY the same way and that was the problem...
Ryan
Ryan
This is interesting. Anyone else care to elaborate..?
Could it be a Harmonic vibration..?
If your rear shackles aren't 100% vertical that may be the problem. You said the top bolt was about a 1/4" in front of the bottom bolt? Did you weld the rear shackle mount to the bottome of the frame rails or did you drill holes in the fram and put bushing sleeves in the frame? Reason I ask if you put the sleeves through the frame rails that will make the spring eyes much closer to the frame allowing them to hit without too much movement.
I think I'd also put some paint on the differential snubber and see if it's hitting, 3" isn't much clearence and a good solid bump can move the rear end more than three inches easily.
I seriously doubt that the shackle torque would be the casues. While it's always a good idea to stick to the factory torque settings if you tightened them good there won't be any slack in those.
Also check for exhaust pipe clearences over the axial or exhaust hangers that may be broken. Lots of simple things can make big noises and fool you. You gotta out smart them.
Dan
Dan
that's not what I said. it was u-bolts, and nota bout havi ng any looseness in them. i'm still trying to find where I heard about this, but i think if the perches are too tight, then as the springs try to slide during acceleration or on bumps, the friction causes it. absolutely not sure on that, which is why I've GOT to find it. I know for sure that was in some manual somewhere that I have here at the house.
dangerdawg said:
in the mopar chassis book under rear suspension section g 3. "over-tighting can cause spring friction,which will produce a booming noise insidethe car."
yup. i found it and came back to post. my 9th edition doesn't have section G3, but it IS on page 316, last sentence on the left column, under the "shims and torque" topic.
I had skimmed the chapter looking for it, but didn't think it was there. i was in the process of reading all my suspension literature fully.
Discussion Starter · #18 ·
Is there a torgue spec on them there u-bolt nuts.
Discussion Starter · #20 ·
green67cuda said:
yep.
doh doh doh I quess I forgot to ask if someone knew the spec!! **(*) **(*) **(*) brrrrrt
1 - 20 of 25 Posts
