1 - 14 of 14 Posts
I have been thinking of changing the rear end springs from their original fitting to the frame with weld in brackets!
I just have a thought if there are any negatives in doing this? Will the rear end be more wobbly when the springs are moved or are there other setbacks?
This is a street car that is intended to do some racing so i want to be able to fit some decent tires on the car!
Chris
Any stability you will lose by mounting the springs inboard will be offset by the advantage of fitting a bigger meat under the wheel well. That's my opinion.
body roll was a concern of mine wheen i moved the springs inward,and my dad thought it would ruin the street-ability of the car, i did notice a slight handling decrease (while being real hard on the car)but its not noticable while cruising the street.,and as mopowers said it's worth the extra meat ;D
Just a note when installing the new front spring hangers in the frame, use a long straight edge or string to get them parallel with the frame rails. It is easy to get them screwed up.
One article I read said to leave the outbaord side of the frame rail intact and to only remove the bottom and inside edge of the frame rail. By doing this you are almost sure to keep the front location of the springs parallel to where the should be. However, be sure to offset the rear upper shackle mount the thickness of the front rail you left in there.
Once you cut the outside section of the frame rail, that inside piece distorts a bit. Don't rely on it being that true. Those rails were press formed in a huge press, there still is some stress in the metal. Mine pulled a little, I was glad I checked the accuracy before it was too late.
Note that if you don't cut the frame out your available tire clearance will be less. If you are worried about handling, go to the wrecking yard and look for a sway bar. A used a Ford piece.
1 - 14 of 14 Posts
