1 - 4 of 4 Posts
i am installing the connectors just as i seen here (build your own) but on the front driver side there is a part of the cross member that protrudes to where it will not fit flat against it. should i cut it out or just try to hammer it flat?
I guess you would have more luck cutting it off and grinding it flat. If you try to hammer it, you'll be pushing it away from where you want to weld.
I just got done with my own home made connectors. That bulge your talking about did'nt move very much with a small sledge so I used my 4" angle grinder with a 6" cut off wheel and it turned out nice.
1 - 4 of 4 Posts
