hi there people, I have a 1965 barracuda and am at a quandry on what to do for engine. the car is 273 4spd I have a 360 core to build have access to a 383 core and have access to a 440 that runs great. what are the dynamics of the 440 vs 383 install and how do these swaps handle when driven and how hard is it to come up with a flywheel and bell housing for the big block? the car will be my wifes so handleing is a factor. also I have an a body 8-3/4 and a dana 60. how wide a tire with the spring relocator can you run and which should I use. the dana needs to be narrowed. I intend to mini tub the car but want to avoid narrowing the 8 3/4 if poss. also will the 4spd live in this thing with a bb? thanks for any replies
Hello, if you want power steering you will have to use the small block or get Bill's Alterkation suspension. The small block is a bolt together while the big block is more of a hot rod conversion with all of the work required.
A short deck will allow you to use HP manfolds for the exhaust.
Related Threads
Big Block Dart Forums
179.3K posts
14.2K members
Since 2005
