What are the requirements for a fuel cell? I have a brand new tank that I could sump, but if there is a requirement for a cell at a certian speed, I would rather not waste my time.
If you run a fuel cell, there are some requirements.
All the lines must run inside the frame rails. They are prohibted from being run thru the cockpit.
There must be an external shroud/or cover covering the exposed lines. The cell must have a ground strap.
If your running a welded on sump, same applys for the sheilding of the lines. It will be self grounding via the straps. Same applyes as to the lines.
Dave
1 - 4 of 4 Posts
