Thanks for all the feed back and will investigate further. I have already installed frame connectors and will install torque boxes. It doesn't have a sway bar but you think that is the way to go? I have the disc brake set up in the small bolt pattern for the front. 8 3/4 SG for the back. Would like to have a cage made for it but want it to be very clean in appearance. Looking for some thing to stiffin it up so it will hook up. All the power in the world aint' no good unless you can hook it to the ground. Any ideas?? I really appriciate you guru's coming to the table with your ideas.
