this is my first attempt at a big block a body, so i thought i would consult the expers. I'm putting a 493/727 in a 68 dart with schumacher engine mounts (original /6). put the engine/trans in friday without much hassle. yesterday i poked around a bit putting in the 2" TTI headers. I had the transmission cross member bolted up and was using the hoist to raise the passenger side of the engine, but there was not enough space to get the header though the top. I suspect i need to undo the transmission mount to allow the engine to lift alittle bit more. anything else? from the top or the bottom? does the steering bar that passes under the oil pan need to come off?
i'm sure many on this board have done this - if someone could share their recipe that would be much appreciated.
