1 - 4 of 4 Posts
Installing a new HDK tubular front suspension, whomever disassembled car in the bast destroyed one of the upper control arm eccentric tabs on the chassis. I can get the alignment close but don’t like the damage on a 9 second drag car. Can I replace those tabs and does anyone make them?
Super Moderator
you might be able to contact the manufacturer as far as finding a replacement if one exists. I'm sure you're not the first to encounter it and they may have some suggestions as far as additional parts sourcing.
wish I had a better answer
Hi.
Just a thought. But if you cut the right size freeze plug in half and weld it in place, that might get the job done. It would basically do the same thing as the old tab. But you'd have to make it fit with some modifications.
Good Luck
Jim
1 - 4 of 4 Posts
