1 - 12 of 12 Posts
Hello everybody
I have two questions which will probably can be categorized in the "bone head category".
1)  I am trying to remove the control arm upper ball joints on my 1965 Barracuda with the larger ball joint socket (1973 and up A body (ø = 1.915")) and I can not get them to budge.  Does anybody know any tricks to getting these off.  I have been using a large breaker bar and have soaked the joints in oil.  Is there anything else I can do?
2) My car is a 1965 barracuda with a disc brake upgrade.  I need to rebuild the front end but I need to verify the year of my front end.  As I mentioned above the Upper control arm is from a 1973 and up A body.  Since the upper control arm is from a 1973 and up A body is it safe to assume I can order a 1973 and up rebuild kit for the front end?  Or are some of the front end parts interchangeable with 1966-1972 A body front end parts?
Thank you for any help and have a good day
Leaving the upper control arm attached to the car I used some stuff call
PB Blaster and let it sit over night. Next day went out using the special
socket with a half inch breaker bar and a cheater bar on the end and both
of mine came right out. (70 Dart Swinger) Good luck with yours!!!
Discussion Starter · #4 ·
i use a small torch with a fat flame to heat stuff but not too hot then spray some penetrating oil. the heat expands the part a bit allowing the oil in the gap. you may want to get some other opinions on heating control arms though. anyone else?
Use an impact, that'll get them out. That's what I had to do to my 73.
My socket is 3/4 drive and I use a breaker bar and long pipe like Jim says. Had to use a map gas torch on one project. When using the cheater it is nice if someone can hold the socket flush on the ball joint.
mike.
Discussion Starter · #11 ·
Impact shoud do it. Or use a long breaker bar for leverage. Well... I must be a total moron.  ;D ;D Cause i tack weld them in when i replace them on drag cars. Seen several pop out race cars that carry the front wheels alot.
[]{} I've tack welded a few myself.
1 - 12 of 12 Posts
