Front only is a big improvement, the rear less so, but still better. Sway bar mounting is the big issue, really. Some use the strut rod while others use a bracket that bolts on with the lower shock bolt. Then, a few use the factory LCA tabs. Any bar that uses the factory tabs will need to run short end links to clear the calipers.
