1 - 4 of 4 Posts
A while back there was a part number for what I believe was a valve stem seal that could be used to keep water from getting in your car at the wiper arm pivot.What was it?
Thanks
i know schumacher has repair kits that work pretty good....kit comes with everything...even grease fittings to install into the pivots/....
http://www.engine-swaps.com/
        Thanks
30 years ago, the valve stem seal our mechanics used for that fix, were Mopar p/n 2121686.
Discussion Starter · #4 ·
Thanks for the feed back guys! How hard is it to put the original seals and gaskets in compared to the mopar valve seal external fix? I would prefer to fix it the correct way,i am not sure if you have to tear the dash apart or what though. Thanks    tnku
1 - 4 of 4 Posts
