trying to wire up the turbo dart so it has street legal lights.
Lots or wiring is cut out ,and as you know when you didn't do it it's tricky to figure out.
I been working on this everynight after work and it seems like i get no where! Heres the exact wiring i have hooked up so far:
Ignition Switch:
Heavy yellow- TO HORN
Heavy Black- To 2nd Male spade connector on back of fuse panel
Orange-last male spade connector on back of fuse panel (but both orange wires that feed out are cut)
Heavy brown- NOT HOOKED UP
Heavy Blue- NOT HOOKED UP
Heavy Red- 4th male spade connector down on the Fuse panel
2 small reds- No where
TURN SIGNAL SWITCH:
Green/red stripe- to starter relay Male spade on the right side of the relay (spade by itself)
Yellow/black- yellow/black
lt green- black/ green stripe
purple- purple/ white stripe
tan- black /tan stripe
Still no lights ,or turnsignals.
Now I did take the heavy red wire from the ignition switch harness and hit it with 12 volts from the starter relay . The parking lights came on ,but they would not shut off when i turn the light switch off.
Now i looked at the diagrams (im not using an ammeter ) and have none of its stock wiring, to me it looks like I dont need to even have to worry about it?
I'm about ready to buy a painless wiring kit and just re do the whole car b/c i can get these stinkin lights workin! If anyoen has a few minutes,please let me know if you see something i did not hook up correctly or something that i did not hook up yet.
Thanks tnku doh
Ignition Switch:
TURN SIGNAL SWITCH:
Thanks tnku doh
