·Although I think cutting just one side (the inside) of the frame is probably the strongest way to put the new boxes in; I can't help but wonder how you are supposed to weld the "top inside" ridge of the new box in. Should there be holes drilled in the exsisting outside frame wall to "tack" through?
Also; on another note; the exsisting stock hole in the frame is only 1/4 inch forward of the stock spring location. Couldn't that be used to mark where you will drill for the new spring location? (Before welding of coarse)
