For a smallblock A-body, I'd definitely stick with manual steering and brakes. Baer would be better for bad weather driving, as they're more corrosion resistant - if you can afford them. The Wilwoods are cheaper, and hold up fine on the street because these cars just don't see snowy, muddy winter type of driving.
A sway bar would be a good idea for handling - and for strip use, it only takes 5 minutes to take the bar off. It's out in front, easy to access. If you want, there's also a cheap power steering upgrade - it uses a reman. Mustang rack, rubber style lines, and we have a revalve kit to change the pressures of a Mopar PS pump.
If money is no object, there's LOTS of serious parts we can do, which we could talk about on the phone. But I assume there's a budget, so I'll recommmend the following -
Call us and order the $3495 kit and get the sway bar option with it.
This kit is the complete suspension with big or small block mounts(your choice), the complete suspension with manual steering, an 11" iron disc brake kit, the shock wrench, and braided flexible brake lines - everything between your column and the lugnuts. The brake kit uses auto parts, so the stuff can be replaced locally, which is a bonus for street cars. We can include the reman power rack for the same price, and then it's just $69 for the lines and $20 for the revalve kit for your pump.
The sway bar option is $249, which includes the welded brackets on the frame and a-arms.
So for $3833 you'll have the complete unit with 360 mounts, power steering and a sway bar, plus the 11" disc brakes. These disc brakes aren't anything massive, but they work as well as the stock Mopar discs. If you want to upgrade later, we can get Wilwood calipers that will bolt right onto this kit, or you can trash them when you have another wad of cash to get the big Bear brakes....
...Or we can delete the brakes altogether and you can get whatever you want right away. I'm easy ;D
Obviously the online store doesn't give you this many choices, so you'll have to give me a call to get it ordered up.
